My car starts to shake when I accelerate gradually but when I accelerate quickly(full throttle) the car goes fast but does not shake I thought it was an alighnment problem but 1 driver told me that I need to change the whole suspension system Do I have to? 'cause it's too expensive for me to do right now(18000+excluding shocks and springs) I won't change the suspension setup unless I'm sure.
Architecture f**d me up
where was my Integra again?
yes i think so too.. but if its shaking when the engine is accelerating slow then its not the alignment, maybe the ignitionzoheb wrote:if its shaking at higher speed......like 80 or 100 km/h.....then the most common problems are the tires and the alignment.
Hey, your problem really seems to be on da suspension. The CV joint or the ball bearings to be specific. My other car had the same problem.... I got it fixed from the workshop.... they repair this stuff if u wanna go real cheap (abt tk1000) or get new parts (just the ones that are damaged not the whole suspension system).
I hope it helps.... take care
Fiz....
Fiz....
can be anyone of the following:Tawhid wrote:actually monk my car starts to shake as if it's floating when i cross 80 km/h the engine runs great no knockin no nothin it's really hard to keep the car straight after 100km/h so where is the problem i don get it wot do you say?
1. damaged ball joints
2. damaged shock absorber
3. loose shock absorber mounting
4. worn or damaged bushings
5. imporer wheel alignment
5. malfunction of steering system
6. damaged or unbalanced wheels
Good luck!
if your car starts to shake once it gets over 80km/h then i think its a problem with your steering wheel not the wheel i mean the system its self
or try a set of thick tyres on your car around 255/55 that might solve the problem another solution is to get your shocks checkd
its only matters whats under the hood not how it looks.. dont mean to be rude but some of you guys only go for the looks and ehn it somes to the realy deal of acceleration you get stuffed up
Syed Taisir huda
Syed Taisir huda
well my car is also having same prob.. after doing the allingment & other things.. like changing steerings rod & other stuffs.. it still has the problem.. i have checked 7 or 8 garages about that... my shaking starts @ 90 & stops @ 100+..
peace
peace
Get the suspension, and wheel balancing checked... go to nippon for it ... they'll tell u what the prob is they do both the checkups there.
If its the suspension get it repaired unless it hasn't been done once before... it'll be a lot cheper but wont last that long. My rollas repaired shocks lasted me 2weeks :( but the suspension lasted a good six months. I had a similar prob in one of my cars... i didnt balance the wheels after getting a new set of tires... i know it sounds weird but aparently the balance was off when i put the new tires on.
1991 G2 integra B16a
