hi, i dunno much abt turbos, but I heard there is a turbocharged engine for my mark II. Sourcing and installing it is a big hassle, any chance that the stock non-turbo engine can be turboed wid a custom charger? Is it possible in bd? what abt the branded turbos like Greddy, HKS, etc... how do I know which 1 can fit my car? any ideas.... :help:
Check the web site.........
hksusa.com, toyota-trd.com, or search the web
instead of getting a turbo charger then fitting it to your car you can import a engine from japan its basically a chaser trd engine but is awesome with twin turbo
its only matters whats under the hood not how it looks.. dont mean to be rude but some of you guys only go for the looks and ehn it somes to the realy deal of acceleration you get stuffed up
Syed Taisir huda
Syed Taisir huda
if oyu want a rough estimate of a good turbo installation
i would say around $4000 australian dollars
inlcluding a microtech ecu
Syed Taisir huda
Syed Taisir huda
Modder
u can tok to da guy in auto start in agrabad ctg...dey r da best around here for engines..dey imported a turbo engine of a chaser tourer v..dunno if its still der or not..but u can order one....regarding installation,der are many work shops in bd,i biliv anyone can install a stock turbo chaser engine..its pretty hard wen it cums to aftermarket turbo kits or supercharger
Keep in mind that you'd need the engine, transmission, ecu, and the complete wiring harness. If you want to take up the manual route, you'd need the clutch assembly, clutch plate, flywheel, pressure plate, release bearing etc. The interior assembly. Make a budget accordingly. Take quotes from a couple of people. Make sure that the engine they import for you, the turbos have no shaft play or oil leaks. Good luck!nitrousFiz wrote:any contacts in dhaka who can import the engine for me? can anybody give me a rough estimate of the price? thanks....
87 RON
Mazda RX7 Type R
Integra DB7
Torneo SiR
Mazda RX7 Type R
Integra DB7
Torneo SiR
