Article not in English though, But DTD should not miss out on this:
AMS chief editor Bernd Ostmann has been the first mag tester that had the pleasure to ride 400+ in the EB 16.4 Bugatti Veyron at VW test course Ehra-Lessien...
some impressions what he said about that day...
the track has been kinda damp in the morning, kinda scary at 400km/h, so 111m/sec without crash barries like in Nardo, well not really, rear wing setup to 2° so 40 to 50kg downforce at rear axle engineers promise that this´ll be enough for a smooth ride even on wet pavement...
through the first corner with 220 easily - absolute brutal accelerating up to 300 within seconds a light left hand bend with 380 - looking into the rear mirror - just an enormous spray but just like they told the EB16.4 is a very smooth car to ride even at that speeds...
the sepcial Michelin tires are working just perfect, they were tested up to 500km/h and before a high speed run they require 3bar pressure - this is one of the points the driver has to go through with a check list and a second car key to unlock the high speed mode - here the two front diffusor flaps are closed, the rear wing selects 2° and the body is lowered to 6.5cm front and 7cm rear a sepecial system is monitoring everything and when only one parameter is not ok the car automatically switches to handling-mode...
the first run ended with "only" 380km/h - the car switched to handling because the exhaust temperatures reached critical 970°C - cooling down the car at 220 or 5000rpm in 4th gear...
the weather gets better, it´s much warmer now and engineers force the AMS team to "act" - next run 398km/h - this time it´s the driver´s fault as he has enabled the A/C on the previous cooling lap costing some km/h on that fast run - so again a cooling lap and then full concentration on the last run with nearly 400 the rpm showed 5800 in 7th gear, now it shows 6200rpm at a speed of 402km/h ...
braking is again a new experience 31.4m (!!!) from 100 to 0 with a 1950kg car...
on the other hand acceleration is also outstanding - measured 25m long black rubber from all four wheels after the standard sprint with launch-control - result: 2.5sec to 100 and 7.3 to 200 :shock:
on a side note - at 400 km/h the EB16.4 needs ONE liter fuel for ONE kilometer so they calculated every 12min a gas station on autobahn when driving 400
Post by deshi_chele »
what language is it?..
I read this on another board. I'm starting to like the Veyron already. Let's see how many people buy it. I'm sure Jay Leno will get one.
Post by auto_freak »
cool post arnab bhai !!
thanks, Jay has to buy one, maybe he already has one in order :D
Post by zoheb »
great post Arnab. wish the article was in English..........nonetheless......awesome find. I like the Veyron.
Image Image Image
Post by Abdul »
I think that Sultan of Brunie has ordered some of them.Here is a Bigatti spotted on the nurburing http://exoticspotter.com/list.php?page= ... cation=all
What is the time for the Bugatti on the nurburing?
Abdul wrote:I think that Sultan of Brunie has ordered some of them.Here is a Bigatti spotted on the nurburing http://exoticspotter.com/list.php?page= ... cation=all
you better ask GTI for this info, he knows everything on the Sultan
Post by Need2Speed »
excellent article!! can't imagine going so fast in a car.
Post by rawfin »
Great News! This is an amazing achievement.
burnin' ruBBer!
A Bugatti in the US
What an AMAZING Color combo. One has been spotted in Colorado. Its still a test mule. They first delivery goes out next month.
Some more from the same car:
Post by rawfin »
Speechless! :quesexclaim:
burnin' ruBBer!
LEX
Post by LEX »
just some more info on the Veyron...
Price: €1 million plus taxes
On sale: Now
Top speed: 407km/h
0-100km/h: 2.5 seconds
Fuel consumption: 40.4L/100km (city), 14.7L/100km (freeway), 24.1L/100km (combined)
Engine: 8.0-litre, 16-cylinder in W-format
Power: 736kW at 6000rpm
Torque: 1250Nm at 2200rpm
Installation: Mid-mounted, longitudinal
Transmission: 7-speed DSG, four-wheel-drive
Steering: Speed-sensitive rack and pinion with hydraulic assistance
Suspension: Double wishbones (front and rear)
Brakes: Ventilated and cross drilled carbon ceramic discs, 400mm (front), 380mm (rear)
Wheels: 20-inch alloys (front), 21-inch alloys (rear)
Tyres: Michelin Pilot Sport PAX, 265/680 (front), 365/710 (rear)
Length: 4465mm
Width: 2000mm
Height: 1205mm
Wheelbase: 2710mm
Front track 1725mm
Rear track 1630mm
Performance
0-100km/h 2.5sec
0-200km/h 7.3sec
0-300km/h 16.7sec
Speed Limits
Bugatti Veyron: 407kmh
Koenigsegg CCR: 388kmh
McLaren F1: 386kmh
Ferrari Enzo: 350kmh
Mercedes McLaren SLR: 334kmh
Porsche Carrera GT: 330kmh
A commercial jet at lift-off: 250kmh
haha this car is out of this world...its a year late...and caused them so many problems...
they build cycle is meant to be 300 over six years....but the F1...which was similar in performance., was discontunied after only 100.
So far bugatti have had 25 pre orders...
