Hello guys,
I need help! big time! i am getting a 50HP NOS kit for my mark2.... me coming in 2 months.... so need to sort it out really soon.... herez the issue -
I need someone 2 find me who can supply me nitrous oxide in DHK.... medical grade is OKAY, have spoken to my local dealer in London, no harm in using the medical grade.... it just smells different.... das it!!!
Now I know the common thing to do will be to check hospitals and dentists... and see who supplies them gas??? but the problem is... i have no one in DHK to really check em out.... and I cant go ahead and buy the 50,000tk kit without knowing that I can get NOS is DHK..... Also I wont be able to bring a FILLED bottle from here due to prohobotted items.... so its basically a dead end unless one of you can help me out as a bro to find NOS....
Waiting 4 ur help.....
nitrousFiz....
nitrousFiz....
Same situation here...need help coming from london end of june...
nitrousFiz, don't worry.... i'm looking for it...
nitrousFiz, i don't know it will help u or not.... i got some info.... u can have N20.. bt u have to take it in the bottle they supplies... & i don't think it would work out...
Many many thanks for the update sakin.... very interesting news.... now there are 2 possiblities -
1. If they supply 5, 10 or 15 lb bottles then I can use it with the kit, if the bottle head is type 4AN, or even use some kind of adaptor.
2. If they only supply in BIG cylinders, then I need to get a NOS pump kit to refill my NOS bottle from those cylinders.
Now for both possibilities, it is crucial to know what type of HEAD or CONNECTOR the bottles uses.
Sakin bro, I know u did a lot for me.... if u can do just more and get a pic of the cylinder... or tell me wat kind of head/connector it uses... it will be of ultimate help.
If you want, you can keep looking for other sources of NOS.
nitrousFiz....
nitrousFiz....
sakin bro... i just found out.... the head/connector is called the bottle valve... and here is what i found -
Bottle Specification: A full flow, (internal bore 2.5 to 4mm) Bottle valve, usually as used for a C02 bottle. It must use a Siphon tube internally that fits into the underside of the valve to draw liquid Nitrous Oxide from the bottom of the bottle / tank. This Valve MUST have (for safety reasons) an Over Pressure rupture disk, as fitted to all C02 bottle valves that you can buy.
I hope this helps!
I hope this helps!
ok.. dekhi ki kora jaye....
