http://www.supercars.net/cars/3549.html
tech specs
Aluminum Maserati V8 w/Dry Sump Lubrication
position Front Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl w/Varible Phase Timing
displacement 4691 cc / 286.3 cu in
power 335.6 kw / 450 bhp @ 7000 rpm
hp per litre 95.93 bhp per litre
torque 470 nm / 346.7 ft lbs @ 4750 rpm
redline 7500
drive wheels RWD w/Mechanical LSD
body / frame Carbon Fibre Body over Steel Frame
front brakes Cross-Drilled Discs
rear brakes Cross-Drilled Discs
front tire size 245/35-20
rear tire size 285/35-x20
f suspension Double Wishbones wVariable Gas Dampers, Coil Springs
r suspension Double Wishbones wVariable Gas Dampers, Coil Springs
transmission 6-Speed Automatic Transaxle w/Paddle Control
